Re.
Usually the pitot/static fittings are from SMC. FESTo is at least the same quality. Only take care to use tubing and fittings in inches and NPT. In Europe is not easy to get, but is mandatory to use with aeronautical instruments. Not the same 1/4" and 6 mm and the difference could be leaks ind system.
