jeffw@sc47
Is the Lycoming IO-390-X available that can have NGK auto/cycle plugs installed instead of aviation plugs?
couple more questions
? Is the engine direct from Lycoming via Vans available with the cylinders ready for the NGK plugs? or is that a modification?
? Which/where/who's - RV14 is using auto plugs and is it a Lycoming 390 or a 360?
Verify if you need long reach plugs for the 390, you probably do.
https://www.lycoming.com/sites/default/files/SI1042AB%20Approved%20Spark%20Plugs.pdf
SDS makes a long reach automotive spark plug adapter.
On this page:
http://www.sdsefi.com/cpi.htm
Jeff,
As already mentioned, you will need the plug adapters.
Give me a call, when you get a chance so we can discuss the P-mags and me doing another tech inspection.
I believe the IO-390 requires it's timing be set at 20° BTC. This means we will need to change the default settings on your P-mags. The jumper will only change the timing to 26.2°, which is too high for your engine.
Jeff,
I believe the IO-390 requires it's timing be set at 20? BTC. This means we will need to change the default settings on your P-mags. The jumper will only change the timing to 26.2?, which is too high for your engine.
Not exactly correct.
For the IO-390 (or 200hp IO-360) that specify 20 degrees BTC timing, the pMag is timed with the crank at 5 degrees ATC. This compensates for the pMag assuming a 25 degree BTC engine.
I recommend first running the engine with the jumper. This will limit advance to 29 degrees (34-5). Later experiment with the jumper removed to have max timing advance at 34 degrees (39-5). A switch to do this on the panel comes in handy.
Carl
Carl
Carl,
I recommend setting the timing at TDC and programming the P-mags for 20° (19.8 is the real number.) This sets the starting timing at 4° after TDC and allows for using the standard process for setting the timing. This solves the problem of some future mechanic from miss-timing it.
Using the tool the way it is designed is always best.
I would not recommend running the higher setting on any of our engines, unless they have low compression pistons.
Jeff,
One other little detail I didn't include in my posts above is that you can download the EICAD program from the Emag Ignitions website and use that tool to adjust your P-mags. Here is the link.
When you are ready, let me know and I can come over and tune your P-mags.
Check your email.
