Tom Martin
This morning I was digging a trench from my field of flooded corn in an attempt to get a large pond of water away from new seedings. Armed with rubber boots and a shovel I was having fun watching the water move down my new trench. It was interesting to watch the interaction with grass and debris as the water flowed. There was a lot of previous floating crop residue and it was easy to see the flow of water by observing these bits of old corn plants.
I stuck my shovel handle in the stream of debris and it was neat to see how the turbulence showed up downstream of the shovel. I went to the shop and retrieved an unused gear faring and shoved it in the stream. The particles flowed nicely around the shape and the two flows reattached smoothly aft of the gear faring. Debris tended to pile up in front of the shovel handle but not the gear faring. The maximum thickness of the faring was very close to the size of the handle. In the flow aft of the shovel handle you can see particles that are actually being pulled back to the handle and then swirl in the turbulent area.
The debris that piled up in front of both items did greatly disrupt the flow and reminded me of videos I had seen of ice on aircraft wings.
I took a short video
http://www.youtube.com/watch?v=G9MIvzDcwjg
