Jetmart
Does anyone have concerns with the plastic bushings used for the routing of the rudder cable from the pedals to the rudder? There are several that are actually used to change direction of the cable slightly which will result in a fair bit of rubbing.
Has anyone with a fair bit of time on them seen any indication of wear?
A few of them are under the baggage floor which is difficult to inspect and change if required.
