"Crowbar" is a term used with power supplies and systems where the system, in this case internal regulator, monitors the bus voltage - IF the bus voltage EXCEEDS a predetermined value then the, in this case internal regulator, SHUTS DOWN the power source so as to not allow the high voltage to damage external systems the power source is connected to.To my untrained eye, I have not been able to visually identify this mysterious "crowbar" that Plane-Power mentions in their documentation. Has someone seen it and can you describe to me what I am looking for? Thanks.
