Surface charge
I think Charlie is right, reinforces what I feared. My cheapo battery minder only charged the Concorde RG-25XC to about 12.0 - 12.2 for about a year and a half, so the battery suflfated and now won't take more. I know sometimes 'equalizing charge' of higher voltage can restore a sulfated battery, and I was kind of hoping that 14.6 might be enough to do that. But 25 hrs of flying, its not getting any better, if anything, slightly worse.
I'm thinking of a PC-680 clone,
Steve,
Often, owners will check a battery's state of charge using only a voltmeter. Often, one or more cells will become sulfated, yet still show 12 to 13 volts with no load on them. Yet, when even a slight load is applied, the battery's voltage will drop significantly. This is referred to as a "surface" charge.
The best way to check a "wet" battery is to use a hydrometer, to measure the specific gravity of the electrolyte.
For a sealed battery, the only way to do a proper check is to use a carbon pile load meter. First, determine the "cold cranking amp" [aka CCA] rating of the battery. Divide this rating by 4. Using the carbon pile load meter, apply a load of 1/4 of the CCA to the battery for 15 seconds. At the 15 second mark note the battery's voltage. A good battery will read 9.6 volts or higher [at room temperature].
Prestolite has a good web page on battery care and testing, below:
http://www.prestolite.com/pgs_training/training_2.php
A carbon pile load tester is an essential tool for testing batteries. Harbor Freight sells a very nice, basic tester. See
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91129
These often go on sale for $50 or $60. I've seen and owned other "electronic" testers which don't actually put a heavy load on the battery to test it. Basically, they are all a waste of money. A carbon pile load tester is the way to go. This Harbor Freight tool is affordable for the average plane owner or for a group to share.
I will say that my HF carbon pile's volt meter was off by about 0.5 volts [read low]. I found this out by comparing it to my digital multimeter. Not a problem, as both meters have a simple adjustment screw, to correct issues like that.
Before giving up on your current battery, try this. Partially discharge it [to about 50%], then charge it up completely. Repeat this several times. If this does not help, it's time for a new battery.
Charlie Kuss
PS The worst thing you can do to a battery is to completely [or nearly completely] discharge a battery. Then let it sit discharged. The longer it sits in the discharged state, the harder it is to drive the sulfate back into the electrolyte. Repeated deep discharges also shorten a battery's life, unless it is rated as a "deep discharge" battery. Deep discharge batteries are commonly sold for marine applications.
