How many devices can you run off a single pitot . I currently have airspeed ,DynonD10A , micro-encoder and autopilot using pitot pressure info . I wanted to add a second grt mini X efis and an Aeolus sence pro.( to run an iPad. Both require pitot/static . That would make 6 instruments running off the pitot . My understanding is static can be used for as many instruments as you like . Is this true of the pitot pressure as well ?
