RV7Guy
My new 7 is about done and I need a pitot static check. I'm at Stellar in Chandler, AZ (Phx suburb). Any recommendations?
The Pitot-Static Check is only required for IFR ops, so you can wait until after you are flying and take it to another airport. You can leak-check it yourself beforehand to save $ paying a shop to run-down leaks. Careful use of a mity-vac works well, track down the leaks and fix them before first flight.
I haven?t had a pitot static check done, but Eric from Chandler Avionics has done transponder checks for myself and others here in Eloy. He is located at KCHD but has come to us on most occasions.
