BJohnson
I'm building the bracket for the Skyview AHARS unit and will be installing it aft of the baggage compartment mounted between the J stinger and the center rib. Now I need to route the two lines from the AOA pitot tube. They will enter at the wing root and turns aft. Where are you guys passing through the bulkhead that also contains the rear spar structure? If it comes out near the fuselage side, are you experiencing interference with the flap actuator bar?
I wanted to turing up the backside of that bulkhead, then turn aft again at the longeron, but am cnocerned about interference with the flap actuator.
Any hints would be appreciated.
