R RViator60 Well Known Member Dec 10, 2019 #1 Can anyone tell me when and where the pitch servos are installed on the RV-14? There's no mention of it in the aft fuselage instructions.
kbalch Well Known Member Dec 10, 2019 #2 RViator60 said: Can anyone tell me when and where the pitch servos are installed on the RV-14? There's no mention of it in the aft fuselage instructions. Click to expand... The autopilot pitch servo is most easily installed when you do the bellcrank and pushrods in Section 36.
R RViator60 Well Known Member Dec 10, 2019 #3 OK...is the servo ordered with the fuselage kit from Vans?
bkervaski Hellloooooooo! Testing Dec 10, 2019 #4 RViator60 said: OK...is the servo ordered with the fuselage kit from Vans? Click to expand... It would come from an avionics vendor such as SteinAir (highly recommended).
D David Paule Well Known Member Dec 10, 2019 #5 And the particular servo is based on the EFIS vendor you choose. A Garmin servo for a G3X, for example, or a Dynon servo for a Skyview HDX. These installations are in Sections 56 and 57. If you want a different EFIS, perhaps GRT, you'll be using their mounting suggestions. Dave
M mturnerb Well Known Member Dec 10, 2019 #6 If using Dynon or Garmin, get servo installation kit from Van's. IIRC separate kits for pitch/wing. Also a kit for yaw servo if you're installing that.
N n982sx Well Known Member Dec 10, 2019 #7 Just to be clear, The installation kits for plans set 56 and 57 from Van's. The actual servos from your avionics supplier.
