ljpgrif
Member
Need to perform a Pitch/Roll leveling calibration on my RV-7A and need alittle info if possible.
Note: This and one more will be my second time I've done this since I was not the builder/Installer. But been flying this plane for 3 years.
Do you level the plane then calibrate or do you raise the nose up 3 or 4 degrees then calibrate to level?
After the pitch/roll calibration is complete.....is it necessary to perform a Magnetometer calibration too?
Larry Griffin
Arkansas
N687VR
What exactly are you talking about? Calibrating what, exactly? An AI or an ADAHRS? Something else?
