Ron Lee
Recently I had lower than desirable oil pressure indications. After I verified that the sender/monitor were correct, I removed the oil screen to find metal. Essentially automatic engine teardown. My mechanic borescoped cylinders and saw something in #4 that was odd (oil streak). When he removed it it was obvious. The end cap (may not the be right term) somehow dislodged and caused significant damage to that area of the piston.
So far most parts look ok but since I will have to do an overhaul at the minimum, I am almost 100% convinced to go to 9.2:1 pistons (O-360 engine).
I am hearing conflicting info on porting/flow matching as to whether it is worth it. There may also be a camshaft that offers improved performance but at this time I have not found any info on it.
Any suggestions and sources for factual performance improvements?
