Ted Farmin
New and better than fuel lube or teflon types. It is EZturn by united. Check on Aircraftspruce web for size and price and part no.
Ted
Ted
Thread sealants are for pipe threads ONLY! All the metal to metal seals should be pristine.alpinelakespilot2000 said:Coincidence. I'm doing my fuel fittings on my tank now. On the compression fittings, is there any point to (or prohibition against) using a thread sealant of some sort? I know that teflon tape is generally a no-no, but is some other type of thread sealant recommended on fuel line fittings? Van's instructions say nothing in this regard.
Steve
There is some great stuff called FUELUBE.
Per the directions, it is "a lubricant, sealant and anti-seize component for fuel and oil line valves, threads and gaskets."
It can sometimes be difficult to obtain, but it works great for putting on gaskets, and for any oil/fuel line fittings, buth on the threads and on the mating faces. (Use a very thin coat on mating faces, such as flare fittings.)
You would be amazed how it helps on all of these fittings. I have been using it for years, as have many of my friends.
New is sometimes better, but I know this stuff works.
Yes and yes.I
- Is it also OK for brake line pipe threads?
- How about plastic pipe threads (pitot/static)?
Try EZ TURN on your fuel cap "O" ring. The cap will lift off and go back on with ease.
Except in the winter!!When OAT's are around 15F or colder, it is all but impossible to get the caps off without tools. There is another thread on this very topic.
Back to this thread, to be clear, flared types of fittings should have no compound. Pipe threads are a different thing. There have been numerous reports of leaks when using EZTurn on things like oil pressure fittings into the crankcase or wherever. A better compound is some sort of paste with TFE or PTFE.
