EXTAAFLY
Anybody have a picture of a Vetterman exhaust on an O-360?
I am trying to determine if what I have is Vetterman or something else.
I have a new LyCon fire breather O-360 on order and thinking about upgrading the exhaust while I am at it.
I did a search but, most of the posts were old and the pictures were from old hosting.
Thanks!
This is the only photo I found on my Vetterman four pipe exhaust. I’m running the standard IO-360-M1B engine. Photo taken before first flight. The plane now has ~200 wonderful hours on it - and the exhaust worked out well (as in I’d do it just like this again).
Carl
Thanks Carl, I have a 4 in to 2 now and planning same.
Hoping someone has a few pictures of the install up around the engine for a O-360 to compare.
My original, before the new cowl had a different technique of install. The pipes were routed through the cowl with glassed cheeks on the bottom for the pipes to exit, leaving the tunnel completely empty.
I have a new cowl now and the pipes are routed through there, but the go in at an angle and the exhaust sort of point at one another. I don't think this is as efficient as it could be. Thus the reason for pursuing a new set up.
Vetterman exhaust picture on my IO-360. Individual stacks.
