dave4754
https://1drv.ms/i/s!Apov9vtfo19v1gzSWB4WCQMGVoaq
Well finally I have hooked up the Dynon Skyview D1000 touch to some of the network stuff i have been fortunate to have purchased used from other builders and fliers.
I would like to thank those private vendors and Stein for having provided me a budget favourable option to EFIS. And they all worked!
The mission for the airplane is simply VFR Day / night so nothing fancy. The Syview stands alone. It is supported by steam gauges for Oil pressure and temp. , as well as Ammetter. The RPM gauge is driven by the engine and the Airspeed and Artificial horizon are stand alone units as well. That way flying at night a power loss is a non issue as you can safely navigate.
Dave
I am so glad to have sourced the used gear which enabled me to afford the SV panel stuff for all Communication, transponder, navigation work etc.
Stein was a big help in a five minute talk and so were the People at Dynon in helping to understand and install the system.
Dave
Is your airplane on a turntable?:confused: I?ve never seen a turn coordinator indicate a turn when at rest, either powered up or not...
Not on a turntable
The faceplate in there is just that a faceplate.
I have purchased a stand alone Honeywell to go in there just dont have it there yet.
