At LOE 2010, I saw way too many RV -A pilots that I know and respect blasting down the runway, either landing or taking off, with the nose gear firmly planted and the elevator centered. Come on guys, pick the nose up! There is no excuse.
I sit on the bench in front of our EAA Chapter club house watching CFIs shooting touch and goes with their students. It's no wonder few of them know how to land airplanes. One instructor's students do pretty good, but a couple of others wheel barrow them on every landing, with no correction being demonstrated.
Just as a note which may be why you observed this was when I landed on Sat around 11:30 the wind was around 15G20, if you keep the nose up to much in these conditions you're asking to go flying again when you don't want too.
When we left later that afternoon it was around 18G23 if I recall. I personally will let the nose down in very windy condition but will keep the weight off it with some aft stick, but not full aft stick, get it to high and you're flying when you don't want to be.
Higher nose means higher angle of attack which means the wing stays stalled right?
Hans
This is a HUGE part of why I'm actively working on getting my CFI. I have a passion, and a "real" job, such that I can direct my passion in a useful direction.
I, like Mr Aronow, let my nose down as soon as I could due to the strong gusty crosswind at 2pm Saturday when I landed. Keep that nose up high in strong, +20 gusts, and you may loose directional control.
Did I get any comments after landing? You bet, nothing else was going on and there were a lot of JUDGES watching.
Scott, good luck with getting your CFI and imposing your methods on the flying community.
During a BFR a few years ago, with over 400 hours in my 6A, the CFI didn't care for my forward slip technique with a 40 degree crosswind. He wanted me to crab all the way to the numbers then kick it straight, I prefer to keep the nose centered on the stripe. Tried one, just about re-kitted the plane, but the CFI was HAPPY. Care to guess how I make crosswind landings today after 1000+ hours?
I only spent 1 day at LOE and there sure seemed to be a lot of judging and critiquing going on, not just on the 9A debacle either.
The CFI was a retired airline captain...
One big reason you see a lot of flat landings is a lot of RV pilots are afraid to slow the airplane down on short final and are touching down way too fast. The A models do really nice nose high full stall touchdowns when slowed properly. Plus with full aft stick you can hold the nosewheel off for a long time. With gusty conditions or crosswind I land three point in my 7. i want it all done flying when I touch down. I'll add half the gust factor but no more than that. Don
And that would be why you keep the nose off.......Pay attention to the position of the elevator (stabilator in this case.)
http://www.youtube.com/watch?v=NMmHYWjEmkY
I wasn't at LOE but I'll admit that I'm guilty of landing too flat more times then I like.
After reading this thread this morning, I decided to working on my landing technique today. I got my landing speed slowed down and made most of the landings full stall and kept the nose off the ground much longer.
Thanks for the inspiration to do better.![]()
I recommend practicing what I call "air force landings". That is, touch and goes without allowing the nose wheel to touch the runway. I saw some Air Force guys doing this one day and have no idea if it is taught by the Air Force, but it looked very cool. I have my flight students do this.
Not an RV, but the dynamics are the same. Here is an extreme example of the dynamics of a fast, flat landing with the added interest of a textbook PIO (Pilot Induced Oscillation.) Pay attention to the position of the elevator (stabilator in this case.)
John Clark ATP, CFI
FAA FAAST Team Member
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
Not an RV, but ...
So, this one would be closer to home.....
RV7A flip at Croft Farm fly-in
http://www.youtube.com/watch?v=NfaCGc16jQ0&feature=related
This video of a 9A NG taxing and take off plus landing on grass shows the sort of movement that would be accentuated in a heavy landing to the point of the wheel tucking under. http://www.youtube.com/watch?v=YYCerJM_Qww&NR=1
The interesting thing is the NG movement is largely back when in the rough rather than up.
Keeping that wheel off the ground as long as possible is my goal in life![]()
The Croft Farm video has gotten a lot of play, but I wish it showed more of the approach and was better quality
Kent,
As you point out, your nose wheel stops rotating almost instantly as you lift off ( . . . at about 2:15 into your video). How did you set the drag on the nose wheel for the video test? Now that you?ve changed to the adjustable Matco axle, have you noticed that the wheel spins more freely? Have you had an opportunity to re-shoot the video to see if there is visually a difference?
Thank You,
Bill Palmer![]()
