SeanB
Hey,
I am getting ready to final attach (hopefully) the engine mount so I can install the landing gear and engine on my RV7. I've read archived threads stating the bottom of the piano hinges (vertical ones) can be very difficult to access for riveting with the mount in place. I would like to install those hinges in advance.
I see in Drawing 45, the end of the hinge run (bottom end) is where the curve starts, near the gear leg. I'm trying to determine how high to go with this piece of hinge.
Thanks!
- Anyone have a measurement of what worked for you?
- Pics?
- Or, could I estimate and leave the hinge material a little long, then attach the bottom "challenging" areas with rivets, the top remains clecoed, and I can trim later?
Thanks!
