If your ADHARS is mounted correctly, there may be two pins on your wiring that are mis-pinned. (reversed). That is really easy to have happen. Could also be a software setting. Start with ADHRS mounting, then check pin out, then check settings.
Pat Garboden
Katy, TX
RV9A. N942PT
My Skyview did the same thing when I first installed it. I installed the ADAHRS upside down. Pretty clear in the plans which way it was supposed to go. That forest was very well hidden by the trees.
It is comforting to me to know that maybe I was the first, but definitely not the last, to put the darned thing in upside down. My first thought is that I must have put the Skyview in upside down!
Nobody should feel bad. I remember reading an article by Van himself, - his personal '12 initially had the ADAHRS installed upside down. He and his co builder, his brother Jerry, were on the point of calling Dynon when they realised. Van blamed Jerry, but --?? .....
Cheers, DEAN....
