Noah
In the 1960's NASA pioneered closed coolant loop garments to keep astronauts cool. These are undergarments with small diameter tubing sewn in to circulate cold water and which are strategically located to pull heat away from the body. Lots of tubing in the underarms, torso, and head, where there are a lot of blood vessels close to the skin. The military uses these as well. http://defense-update.com/features/du-2-07/infantry_armor_cooling.htm
http://nsrdec.natick.army.mil/media/fact/techprog/AW_MCC.htm
As I sat in my hot cockpit in the direct sun yesterday I wondered why we aren't doing the same thing in our RVs (or maybe somebody is).
I have looked into some of the ice chest coolers available but these seem horribly inefficient in that they attempt to cool the entire cabin when all I really need to do is control my core temperature. Cool core temperature = no sweat / happy camper. Controlling core temperature would also mean a lot lower coolant load than coooling the entire cabin, meaning a lot less ice and lower weight, obviously very important for aircraft use...
Some of these are marketed to the motorcycle crowd, others for medical use. Veskimo has a nice unit:
http://www.veskimo.com/personal-cooling-system-9quart.html
And Vitalwear's has a medical version called the RecoverWrap which has several different wraps that go on various parts of the body:
http://www.vitalwear.com/recoverywrap_system_product_info.cfm
Here is another from Taclights:
http://www.taclights.cn/PCS.htm
And another marketed for aviation use:
https://www.pilotcooling.com/shop/index.php
Seems like these might be well suited for our unique application. Anybody got a PIREP on any of these personal cooling devices that are on the market?
