Perhaps a really dumb answer
Looking at the preview plans one thing is for sure; I've never in my life ever read a blueprint. As a foot and ankle surgeon I work with tools and hardware a lot but alas no blueprint reading skills necessary in the OR.
My lack of "mechanical training" reading blueprints is frustrating. It seems like I've got to stare at the dang drawings and read the "directions" for a lot of time before it sinks in. Any suggestions about how to educate myself in the accurate reading of blueprints so it is second nature? Thanks.
Well as a surgeon you are of average intelligence.
![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
More important you can think in 3D. You know anatomy right, anterior, posterior and so on. No difference, we have
STATIONS (front to back from a datum)
WATER LINES (bottom to top from datum)
BUTT LINES (left and right from datum, center line usually zero)
Vans manual gives a little primer on blue print or mechanical drawing reading.
You probably can get a little book on it or even Google it and read some primers.
There my even be "Blue Print Reading for Dummies out there".
When you get the parts, the drawing you read, think, fit, check, measure, check again, read again, think, check and THAN DRILL.
You will get it. You will just be slow at first, which is fine and actually good. Rushing a way to make mistakes. If you are tired stop. TAKE YOUR TIME. If in doubt, WAIT IT OUT. Wait to the next day and call Van's and ask them or post on the list to verify. Sometimes the drawings are NOT clear and can be miss interpreted. However Van has made great strides in his drawing and manual, but it is not perfect. There can be mistakes in them, so ask questions.
Now there are some tricks and gotchas in reading drawings. One tip is try and think ahead like a chess game. You want to look at ALL drawings that may reference that structure. Try to picture the WHOLE assembly in your minds eye. That will help in the sequence of assembly and possible interference.
Remember you are also working with pre-made parts that fit well and are even PRE PUNCHED. It almost builds it self.
One danger is OVER Confidence. You will get to the point where you will see how it goes together with out even looking at the drawings. However I would refer you to the above, there are gotchya's if you don't understand ALL Dwgs that affect that particular assembly.
Enjoy the learning process.
