henriquerv9
Active Member
hi all,
Just would like to receive performance information from guys using a 180hp engine. What propeller are you using? what performance and fuel burn?
I am into ordering a new engine from aerosport to change my actual 125HP, just dont know if Worth more an IO360 than a IO320.
My main mission is mid cross-country (200/300nm). If i put a IO360 and put the trothle a little back it worths more than a IO320 with 75% power? The fuel burn will be around the same? What about the engine working in less RPM?
Regards
Henrique Castro
Regards
Henrique Castro
