I installed mine attached and above to the center bracket for the rudder peddles and the cable comes right to my panel.
Another possible and good location is right behind the subpanel where the brake hoses are suppose to turn downward to the tunnel. The only negative part about this location is that in most cases there is good bit of wiring for crossing this section. Mine has worked flawlessly so far.
