Brockster
Does anyone have a source for a pivot that will fit the parking brake valve and cable that Vans sells. In case I don't have the right name it is the connection where the cable attaches to the parking brake valve to move the lever back and forth. The pivot attaches to the cable, usually clamped with a screw, and a stem off the pivot goes through the lever held with a cotter key so it can freely turn in the lever as the cable is moved. Thanks.
