Driving '67
Friend
Hi all, having a hard time figuring out the correct fitting P/N from various vendor websites and I thought I'd ask the gang here.
I'm currently working on the parking brake (Matco) setup for my RV14A and need a couple of AN fittings. The fitting required needs to be 45 degree AN to AN as I'm using Aircraft Specialities SS brake kit. Any suggestions would be appreciated!
Thanks Jim
AN823-3D as we use -3 hoses and hose ends for the RV14 package. The parking brake valve has NPT threads.
Tom
So you need a 45 degree union? Your not going to find that in a proper An fitting. The aftermarket race car part AN style fittings (china) has them inlarger sizes, not sure about -3 or -4 typically used on brake lines.
The fitting required needs to be 45 degree AN to AN SNIP
