Flying EMT
Active Member
Does anybody have a part number / retailer of an USB panel jumper that is shorter than three feet to put on my Dynon system? All I need is less than 12 inches. Ben
Just remember you will need a 2A USB port to charge an iPad, most are 1A and the iPad will not charge while in use.
For panel mounting, something like this might be better so it's flush with the panel surface.
http://www.datapro.net/products/usb-panel-mount-type-a-cable.html
