praterdj
I am in the process of laying out my panel. This may be a goofy question but I was wondering how much of the view on the top of the panel is blocked by the glare shield on an RV-8? :confused:
I plan on being secured by the belts and don?t want to place the critical instruments too high and have to lean forward to read the gauges. :eek:
Any rules of thumb from the guys flying 8's?
I?m about 6'-5" tall so I will be setting pretty high.
Thanks for any input.
Donald
RV-8 in progress
N-284DP (Reserved)
Don,
I'm only 5'9"", and that puts my head a LOT lower than yours will be, but I can see the top screws in the panel without a problem. You can also trim the Glareshield however you would like, and can also have your seat cushions cut to a height that you like.
Paul
See the World
I am 5'11" and when flying my mates RV-8 I have around 1" clearance to the canopy. Here are two shots I took in flight.
As you can see nothing much is obscured.
Pete.
Thanks for the input guys and thanks for the pictures!
Looks like I can do whatever I need to do to make everythng fit and trim the glare shield.
Thanks again for your help.
Donald
