Okay you painting experts, I need some help! Yes, we (my RV partner & I) decided to use some checker board on the Vert Stab and we are painting the RV-6 ourselves. We like the look of a fade away from the solid color into the checkerboard. Looks like we would just spray the solid color around the perimeter of the checkerboard and the spray pattern would create the fade away effect. Is it really that easy? Maybe mix some clear in to build transparency? Whose painted a fade away and what technique did you use?
Thanks for your help!
