Polyester is OK
Dayton Murdock said:
Hi Everyone
Can I spray polyester primer filler over my epoxy cowl? Will the primer eventually separate from the cowl? I have used this type of primer on the wheel pants, wing tips other polyester fiberglass parts
No problem if everything is clean and degreased.
This is standard sailplane technology. When German gliders are refinished, the epoxy they are made from is painted with polyester primer and then finish coated with polyester paint. After a sand (within 24 hours before the paint hardens) and then a polish a day later, a glass like surface is obtained.
This combination does stick and has been used for decades (my Mini-Nimbus is now 20 years on it's refinish) mostly using Prestec paints.
Good quality polyester paint and primer is OK on epoxy... and I just remembered it's one of the standard Rutan finish methods - not surprising since he started off next door to Fred Jiran in Mojave, who was one of the glider repair guys of the day...
This brand should be available locally from auto body suppliers, and works well....
Fibreglass Evercoat 391 - Feather Fill
The major complaint with it is that it sands too well, and makes LOTS of very fine dust that gets everywhere...
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
.....wet sanding will help this....
gil in Tucson
