Question:
Can you paint over Lacquer primer with DTM(Direct to Metal) Epoxy primer that is reduced with Urethane Reducer? Reason I ask is that the surround on the windshield has Lacquer primer on it(the fiberglass surround) and am going to use the DTM on the rest of the fuse bare metal. The DTM is NOT self-etching epoxy primer.
Thanks in advance,
Mike H 9A/8A
Thanks in advance,
Mike H 9A/8A
