Barry_Barry
Member
Hello Gaggle:
I'm totally new to this and request help.
I'm stripping and repainting the plane. So here are some of my questions:
1 - I was told about a stripper that sprays on and then drys with the removed paint. I think the name was KOLAR. It is suppose to be very aggressive on paints and not attack plastics. But I can't find any info on it. Anyone know of such an item?
2 - I wish to do a Scratch & Paint (sand & paint) because the original paint is OLD SCHOOL chemistry and is bonded very - very well. What PRIMER do you recommend?
3 - Keeping with Primers - This confuses me. Why do they call some primers Acid Etch Primers, when ACID is NOT used on aluminum... It should be a strong Alkaline for cleaning the aluminum?
4 - Chem Film (some know it as Irridate or Alodine) - Why would you use it IF you are going to paint on the Primer - - - Acid Etch Primer immediately after stripping/ sanding?
5 - Doesn't the Acid Etch primer remove the Chem Film?
6 - What Paint? I know, I know... this is a personal preference item but it should be compatible with the primer.
Thank you for the help,
Barry
Barry
