Happy New Year everyone!
My engine mount is unpainted and is slowly rusting whilst waiting to be installed.. I don't want to leave it like that so I was thinking of painting it to slow/stop the surface corrosion.
My question is.. should i metalprep the mount to remove the light surface rust that is on it now before painting, or should I remove the rust by mechanical means only? My concern is that any phosphoric acid solution may weaken the mount in an non visible way. The intended paint covering will be an epoxy primer, followed by a gloss white topcoat.
Your advice on how to prep the mount for paint would be greatly appreciated!
