C Chappyd Well Known Member Mar 9, 2008 #1 Has anyone found a spray paint in a can that matches Vans pearl gray powder coat? I have some small paint jobs that I'd like to do that will match the powdercoat parts. Vans just sells touch up in a small bottle. Thanks
Mike S Senior Curmudgeon Mar 9, 2008 #2 A lot of paint stores can color match the powder coat, and then load that mix into a spray can for you. Make a few phone calls, you will probably find what you want pretty easily. Good luck.
P PaigeHoffart Well Known Member Mar 9, 2008 #3 Previous threads http://www.vansairforce.com/community/showthread.php?t=19856 http://www.vansairforce.com/community/showthread.php?t=6561
