hecilopter
In an effort to solve the never ending question of why airplanes which are similarly configured have such widely varying oil temps, just looking for data from local observations.
It has been noted that engines equipped with piston squirters will have higher oil temps, so we need data from engines without piston squirters.
Locally we have 3 unpainted engines (and one with the thin lycoming gray), all run oil temps in the 160 - 180 F range, even with ambient temps over 100 F.
Then there are 3 painted engines, esp. the oil sumps, varying colors, red, blue which all have oil temps 200 - 240 range even with ambient temps in the 85 F + range.
All configurations are the standard #4 mounted van's oil cooler, baffling, etc.
Looking for 2 data points just to see if this is an anomaly or if there may be something to it. No need to reply if you have piston squirters. Looking to see if maybe the painted sump is acting as an insulator and holding some heat in.
1. How many unpainted engines out there with high oil temps (200 F+) ?
2. How many painted (not the thin lycoming gray) engines with low oil temps (<185 F) ?
If there are several replies then no need to research this one further, just curious and trying to figure this out.
Thanks!
Thanks!
