John Tipton
I'm New Here
HI Guys
Anyone else had a P2 removable control stick that isn't, as arrived from Vans the stick is stuck fast in the lower socket, anyone else had this, any suggestions of removing the stick to make it 'removable'
Regards - John
Hi John
I recently replaced the original with a new one from Vans and it’s a snug but not tight fit in the lower assembly. If you can get yours out it’s probably just a burr making it stuck, clean it up with scotchbrite and should be fine
Catch up next time your up at EGTE
Regards
Nige
