bkervaski Hellloooooooo! Testing Nov 18, 2020 #2 yarddart said: P mags when do they need to be serviced how many hours Click to expand... 100 hours or every annual but there are different versions, best to check with the manufacturer.
C cojaken Active Member Nov 18, 2020 #3 My understanding is they do not need to be serviced, unless the interval inspection described above reveals a problem.
[email protected] Well Known Member Nov 18, 2020 #4 check for shaft play... Whenever you pull them for inspection, take a close look at shaft play... in my experience it is a good sign of wear that will eventually lead to timing irregularities.
