I?m assuming you shifted from a mag to the pMag. If so, did you use the same wire for tach input and if so, did you remove the inline resistor needed when using a mag to feed the Dynon?
Carl
I just used the P lead to control the New P mag. I guess I need to run a wire from the p mag tach output to the dynon.
I think the dynon is wired to the starter key right now. That is how it is explained in the dynon manual.
Carl
