Moeggeploeg
Member
P mag manual calls for P mag to be grounded, then to power up the 12 V bus.
I am using one Lt and one Rt three way toggle switches to operate the P mags.
Off: grounded, unpowered; Test: ungrounded, unpowered; Run: ungrounded, powered.
Leaving the P mag switch at the grounded position and then powering up the Master switch, brought a momentary green, followed by a momentary yellow LED. No red light.
Lots of tinkering to check all the connections to the P mags: ground, kill, power etc.
Solution?
Ticking the Lt and Rt mag boxes on the VPX screen, magically revealed a red LED on the mags!
G3X. Touch EIS>Engine>VPX and scroll down to the P mag boxes.
(Seems that the VPX un-checks the boxes when switching off the Master switch.)
Solution?
