lostpilot28
I'm looking for some additional troubleshooting steps. I taxied out to the run up today to go flying, and I started on my P-mag checks at 1600 RPM. I had the right PMag completely off and when I switched the left PMag to "Internal Power", the engine quit. I repeated this about 6 or 7 times, completely cycling Master Power each time.
My P-Mags are wired the same as Bill Repucci's and I can't see how this would be a loose wire or grounding issue. The reason I say that is because the Left Mag runs fine on ship's power (with the Right Mag off). The engine only quits when I put the left Mag on Internal Power.
Any ideas? Thanks in advance!
