Karetaker
Howdy everyone. I have remade new plug wires and checked the system using the "Pull Thru" test in the P-Mag manual. It appears I have a single dead spark plug wire terminal on one mag. I have swapped good wires/plugs from other terminals that have spark and they do not spark on this one terminal. (The 3-4 bank on the P-Mag.)
Speaking of banks; the manual states that the terminals within a bank are interchangeable. That seems to me that they are electrically connected somehow inside the mag. So, I am confused as to how one terminal wont fire, but its mate is fine.
Both mags were sent out for service/software updates a few years back; I do not recall the exact timeframe. But the mags only have about 16 hours on them now. If it matters, these mags are from 2012 and have the gold bodies.
Anyhoo...any suggestions on what I might be able to do/check prior to sending this thing out for service? (again)
Much obliged.
Pmags of this era use COTS Ford coils. You could probably have Amazon ship you a coil today and swap it out for less than the shipping cost back to Hartzel.
Got a part number? Googling "COTS Ford coil" doesn't yield any definitive results for me. As an aside, has anyone here done an autopsy of an EMAG with pics for our edification?
Interesting...I'll look into it.
I am interested in disassembly of a P-Mag to lean more about them. (just not mine...yet...)
Found this:
Post #8
Doing some fast searching on Amazon, it appears part number FD497 is the same item for the coil 26C1081.
Just put your spare on, and then you'll have time to play with the one that's failing. (You do have a spare, right? RIGHT? :D )
Take care removing the screw from the coil pack - they seem to be on very tight and the screws are glued on with locktite - I almost stripped one trying to get it off to put on the adel clamp.
Your problem doesn't sound like the coil. Not famaliar with EDIS stuff, but in general, wasted spark coils fail in pairs. It is closed loop between the two plugs on one coil. Energy flows out one terminal to plug, jumps gap and goes to block then to next plug, jumps the gap, then back to the other coil terminal. Break that circuit and neither plug fires. I thought EDIS was traditional wasted spark, maybe someone else here can confirm that. Wasted spark coils are not grounded, so spark energy does not return to the coil via ground, like traditional coils.
EDIT: This may be a generalization and very possible that the EDIS coils are configured differently to allow one plug to fire in a pair. It is possible to have 4 coils in there using a grd return path even though they fire them in a paired wasted spark manner. I could see ford doing that to limit problems from a single plug failure.
Thanks Larry. What you describe above is what I am curious to know specifically with P-Mag and how they operate. I will be removing and bringing home my P-Mags today to see what might be going on.
Much obliged.
Just experienced an NGK plug failure. You certain they're all good?
I had a series of multiple PMag failure/repair/failure cycles back in the 2015-17 time period. They've performed well the last 6-8 years. I believe several things changed for the better at Emag in that timeframe. (Might consider proactive overhauls with close attention to actual replacement of suspect parts).
I think I remember, in some thread back some months, that there was a guy that did have a wasted spark coil (Lightspeed unit I think) fail on one output. I was taken aback I recall as I didn't think they could fail that way.
Of course it may be my memory that's failed, not the coil.
Ignition Coil: Make sure that none of the coil wires on the three pin plug located on the side of the ignition is loose. If that checks OK you can disconnect the connector plug and measure the resistance (ohms – not continuity) across the three terminals as follows: Outer pins to center (measure each separately) Outer pins to each other 0.6 to 0.7 ohms typical 1.2 to 1.4 ohms typical Remove the spark plug wires and measure resistance between the terminals (within each bank). Terminal to terminal (measure each bank separately) 9,000 ohms typical
Much obliged.
The coil port will burn out if the spark plug is somehow disconnected for some duration. If you look the connection in the coil at that one that is not firing, there are good chances that has burnt mark (darker)
Here is what you need and is fairly in expensive.
Carquest 26C1081 Ignition Coil
and
For Ford Mazda 645-302 3U2Z14S411TNA Ignition Coil Pack Wiring Harness Connector
I have a write up in you search the search engine here.
Good luck
I have the documentation from E-Mag about troubleshooting the mag and coil. I also now have a new coil and am waiting on the connector from Amazon. Once assembled and I get a ground run completed, I'll report back on the results.
Got a part number? Googling "COTS Ford coil" doesn't yield any definitive results for me….
Within the aerospace industry, “COTS” is a common acronym that means “Commercial Off The Shelf”. In our context, it just means it’s something you can buy and use as is, rather than a bespoke part. Apologies for assuming my industry jargon was universally understood.
Ah, now I feel old. I'm not that old but I did see a UFO yesterday evening.
