Ben Beaird
Active Member
Has anyone with an Emag or Pmag using the auto plug harness settled on a plug style?
I will start out with Emagair's recommended "setup" plug unless current users have determined, through tests, a better alternative.
Thanks in advance,
Ben Beaird
-6A
Ngk Br8es (#5422)
I'm pretty sure EMagAir recommends the NGK BR8ES for use with their ignitions. I don't have an E/P-Mag, but I can tell you that the BR8ES plugs have been working great on my IO-360-A1B6 with Lightspeed Plasma II ignition for over 800 hours.
$1.61/ea from Rock Auto Parts. http://www.rvproject.com/pricewatch.html for the link.
I would not hesitate to use BR8ES plugs.
)_( Dan
RV-7 N714D (812 hours)
Ngk Br8es
Ben,
I have been running NGK BR8ES plugs with my Emag for around 100 hours. Gap wear is almost negligible, performance is up to expectations. Plugs cost around $1.70 from Reilly autoparts. I don't know enough about plugs to say what benefits would be available from switching to other models.
Pete, RV-6A, O-320
Auto plugs
I'm using the emag/pmag with the auto harness and the plugs as Dan mentioned. Everything is working great with 44+ hours now.
The toughest part of the install is making the harnesses!!! I highly recommend the auto system.
Darwin N. Barrie
Chandler AZ
