Frank Smidler
I have a RV-6 with a Grand Rapids EIS. I am trying to decide were to mount the Outside Air Temperature probe. Where have others mounted them? If you mounted it in the wings or aft fuselage how well did it measure the tempurature?
I am thinking of gluing it down to the inside surface of the wings bottom skin in the first bay on the passenger side. I can leave engough wire inside the wing so if I have to remove it when removing the wings I can pull the wing partially off and just scrape it loose with a puddy knife.
RV-6 in the finishing stages.
