I'll stick my neck out and state (for reference next time) that I don't fully agree with the method of rear baffle install in the instructions. I think they tell you not to smear a good layer of proseal on the baffle flange for fear of pillowing between rivets. Poo! Also, the instructions talk about pushing a bead along from the skin to form a fillet, or something like that... I put a nice thick (3/32"?) layer of proseal on the baffle flanges before install. With two people, you can pry the skins apart just enough to not wipe all the proseal off while you drop it in. Then a cleco in every hole and a little pressure between clecos to be sure things are squeezed down. The squeeze out forms the interior fillet. I've done four of my own tanks this way, no pillowing, no leaks. I also put a little proseal in the dimple or countersink under the head of every rivet. Just my 2c.
