Also, if you are using the Van's wiring harness, you need to replace the two wires coming out of the Autopilot roll servo and running to the aileron trim motor with shielded wire per Garmin. The CAN bus wire will also need the shield ground to carry through the connector at the wing root.
JET![]()
