I want to install a switch that will supply power to two devices (in my case, GNX 375, and GTR 200), in lieu of a separate avionics bus with relay. Together they would typically draw 4.2 amps (9.3 max). Essentially, this would be my "avionics master", being the only two devices I would want powered OFF until after engine start.
Will a normal SPST switch work for this? I am using fuses, so separate wires from the fuse block, then spliced together to connect to switch?
Electrics aren't my forte, so please excuse my ignorance here.
