7DeltaLima
I have one EGT that is ~150-200 degrees hotter than all others. Understand it's not the exact temp that matters but in this case I believe it's indicative of an opportunity.
CHT's, oil temp, oil pressure ... great.
New Lycoming IO540.... about 25 hours
RV10. Pretty much stock built.
Mags with G3I. I don't think it seems to matter whether G3I is on or not but can't specifically state that I tried this in an extreme lean situation.
what I've done and kind of in order
Switched probes... yep it's the number 2 cly
Cleaned & rotated plugs... not the plugs. wasn't expecting it to be but start simple![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Pulled and Cleaned the Injector on #2. no joy
Pulled and cleaned fitting in spider and blew through feeder line between #2 and spider.... no joy
I pulled some data from the AFS this morning... running around 2350 squared.... #2 seems to peak at around 14.3 gph while the remainder start peaking around 12.3. Engine definitely runs rough when getting to the level that the remainder of the cylinders are peaking.
At normal cruise... running rich, engine seems to run fine and smooth but the EGT is still hot on #2 compared to the remainder of the cylinders.
I've read to check for induction leaks but haven't chased down what that really means or how to? I'll pull my Sky Ranch book out shortly
Next step for me....
I'll probably switch the injector in #2 for one of the other cylinders just to see if it follows the injector...
I'm about out of ideas.... what do I look for next?
Thanks in advance for any ideas,
Doug
Doug
