avengingangel
Has anyone tried the motocam 1080p? This particular model I'm interested in has audio and gps. Camera looks to be very similar to the contour.
yes I bought the 170 stealth about a month ago with the aux mic input cable.
I have used it once. mounted in the cockpit. I wasn't very happy with the first session but my second will improve.
audio was poor when coupled directly into my intercom but i have a mic now which i will place inside my headphone.
the video was ok although my hand held flip video camera is an obviously clearer image.
i didn't find they had enough mounting brackets included.
I bought the stealth because it had variable fps. I've tried it on 30. Will any other fps get rid of my rubber prop?lol
O.K., lots of info here for the "all-in-one" style camera.
What is a good setup for a central located recorder, with 3 or 4 cameras (lipstick style) mounted in various places in/on the plane???
Hey flyboy and behrent. heres a video i took the other day. Im happy with this unit and the audio that I was after seems to work really well. In all honesty I didn't have any issues with the mic in my ear. Sure it would be nice to have the audio plummed direct but as I said earlier there was just to much noise in my sytem with it used that way. let me know how your audio works if you plum it direct.
http://www.youtube.com/watch?v=oIci8aArRvM
also i have a video I took with myflip video at this site. It may be wrong of me to say the flip is more clear. distance from the panel may be the only reason I can make numbers out. you be your own judge.![]()
What a bummer. I want one under the wing also but haven't found any good options either.I just received my Stealth Drift 170HD this week end, and while working on an under-wing mount on the RV10 I did try the remote from the cockpit. It will NOT activate the camera while under the wing.
Ouch, bugs in the teeth in the summer and ice on the ears in the winterMoving it forward of the wing allows it to activate, but unless I can convince Carol to fly on the wing and hold it I don't think the remote is going to do the job once it is mounted.
Nice Video and sound. The audio portion was clear on the ground and fairly clear while in the air. It looked pretty bumpy up there and it seemed you had to adjust the mic in your headphone a couple of times. When you did, the sound quality improved.
I couldn't tell for sure, but do you have a Sigtronics intercom? I was wondering whether the sound quality issue you had before plugging directly into the passenger headphone jack was due to it's lack of noise filtering compared to a stereo audio panel/intercom like PSE?
It would be nice to hear from others who have tried interfacing the aux mic on these cameras to a stereo audio panel/intercom like PSE or Garmin.
BTW, I watched your other video of a landing and if that is the one you used your myflip on, WOW, it was a better quality video![]()
