Clouddancer
We bought a original, older type engine cowl with our RV-4 project. This cowl seems to be fabricated with polyester resin and has a white gel coat. It has no honeycomb core as the newer cowls.
We are currently in the process of fitting the cowl... and it is rather floppy
, needs quite some trimming and glass work.
Aligning upper cowl with a laser.
What have builders, that have this older type cowl, used as a resin? Did you stay with polyester or did you use an epoxy system? I'm interested as well in the surface prep before painting: any specialities (products and techniques) that you used for the gel coat?
I have read as well, that some of those cowls show some deformation in flight: http://www.vansairforce.com/community/showthread.php?t=127490&highlight=polyester
Have some of you used some way to stiffen the cowl? Any experience on your modification?
![24611864902_dcf1bd9e29_c.jpg](/community/proxy.php?image=https%3A%2F%2Ffarm2.staticflickr.com%2F1540%2F24611864902_dcf1bd9e29_c.jpg&hash=566268ded6caf34925ab7f42184c10d7)
![24101471394_5e505fb4e9_c.jpg](/community/proxy.php?image=https%3A%2F%2Ffarm2.staticflickr.com%2F1698%2F24101471394_5e505fb4e9_c.jpg&hash=446125548ffa66fa0604908fdf7f965e)
