Vince Koehn
Anybody have input on whether it is worth the upgrade from the older style Hartzell to the newer "blended airfoil" Hartzell prop?
Thats a good one. If your old prop is working you should stick with it in my opinion, at least to overhaul. The BA prop is AD free and does give about 3.5 mph more top speed. It's a better prop and I want one as well. You know the price. They just went up.N819VK said:Anybody have input on whether it is worth the upgrade from the older style Hartzell to the newer "blended airfoil" Hartzell prop?
Good point and absolutly right if you have the 7496 "BA" blade but not the 7497 "BA" blade. The 7497 "BA" says "placard none" (limits/restrictions) on the O-360-A1A.Rutus said:George, I have the BA on a stock O-360-A1A and I'm pretty sure it DOES still have some restrictions: (1) exceed 2600 RPM only for takeoff, and (2) no continuous operation above 22" MP while below 2350 RPM. That's the way I placarded my panel, and I'm sure I took those details straight from the Hartzell paperwork that came with the prop.
It is the only prop I've used on the RV-6, so I can't compare with others, but it does have great all-around performance, and the restrictions noted above are very easy to live with.
John
Interesting... did they happen to mention if there would be any possible disadvantages to using the 7497 (BA blade for 200HP) on a 180++ engine? I have a mildly pumped up 180HP parallel valve engine so this is of great interest to me.db8 said:Hartzell has two blended airfoil props now. One is for a 180 HP parallel valve engine, and the other one is for a higher hp engine (angle valve or pumped up parallel valve). I have chatted with Hatzell's technical support staff and a pumped up parallel valve that generates more than 180 HP falls in a grey area -- ie, I am going with 9:1 pistons, have the Superior cold air induction sump (that will be replaced in Sept?), dual electronic ignition, fuel injection --so I will probably have something like 188-190 HP? Kevin got back with me after talking with his tech guy, and they recommended the higher hp BF prop for my application.
First off, screw that. These compact hub props AREN'T breaking all the time and warrenting this AD. This is really a SHOTGUN ad when in comes down to it. People that have problems with cracking are the aerobatic pilots, which there is already another AD out for, and people that don't get their props serviced at the recommended intervals (6 years or 2000 hours). If you are building an experimental and already have the prop, KEEP IT! Don't let hartzell taken any more of your money. Have the inspection done, and if no cracks turn up, fly with the thing. Since you have an experimental, there is NO requirement to comply with this AD. While I don't suggest ignoring it completely, I feel that every 100hrs is excessive. If you flew your airplane to a prop shop once a year and had this $100 inspection done, wouldn't that be better than spending another $6K on a new prop.andymeyer said:I talked with Hartzell yesterday... I've got the hub with the AD sitting on my garage floor right now - got it cheap so I'm not complaining.
Walt at Hartzell was extremely helpful and suggested that I order a new prop - I know - helping me spend my money to the tune of $10781 for a HC-F2YR-1F with the F7666A-4 blades... Good deal is that when I sent them my old prop, they will turn it into aluminum soda cans for me, and send me a check for 40% of the price I paid for my new prop - Over $4,000. Catch is that this deal runs out in September. They are trying to get the old hubs off of the street by offering this deal. Just think, I could be sitting in my RV drinking from my old prop.
Hope this helps...
Andy
