In the next couple of weeks (probably after Oshkosh, realistically) I hope to drill the rivet holes in the horizontal stabilizer skin of my -3. Van gave pretty detailed instructions on how to do this with the skin draped over the skeleton, which is mounted on the jig to keep it straight. Sounds pretty straight-forward.
However, my eyes cringe at the sight of uneven rivet lines, and I'm having doubts about whether Van's method will allow my lines to be as straight as I want them to be. Even if the rivet lines are drawn straight before I drill, I'm having trouble picturing accurate blind air-drilling in my head.
So, Old School kit builders out there--- Before the days of pre-punched skins, what methods did you use to make your rivet lines straight and accurate? Did anyone pre-drill the skins, then match-drill the skin to the ribs/spars? Or did most people do as Van suggested, with things turning out better than expected?
Thanks!
Thanks!
