The reason I am posting is this is not for the flying RV guy who is considering this modification but the guy who is building or thinking about building an RV7/9 and considering this mod.
I am 6'1" with a 34" inseam. Therefore I have a tall upper torso and long arms and require extra long sleeve shirts. I fly a RV-7A tip-up. The seat attach is built to print. I do not use the hinged back brace and my seat back is attached to the middle hinge on the floor. My bottom seat cushion is about 3" thick with a 1.5" back cushion. My head clears the canopy by about 2". I have adjusted my seat cushion height a few times and find this configuration to work the best for me with good over the nose visibility. My arm to instrument panel length is very comfortable. This setup works for my size frame.
If you are a tall guy like me and considering this modification you need to spend time sitting in an RV-7/9 with the proper seating setup before you decide.
Now if there was a way to instantly widen the RV-7/9 by about 2" without any work that would be a modification worth looking into .
-Allan can you focus on this for a few months?
